OcUK Staff
- 26 Nov 2014
- Stoke
Available for preorder, we have the new G1 Liquid Cooling Distro Plate from Lian-Li. Compatible with the very popular PC-O11 Dynamic and the soon to be released PC-O11 Dynamic XL, the G1 is perfect for creating clean watercooling builds in both cases, with an integrated DDC 3.1 PWM pump rated for 500 L/h and 2.6m output, along with digitally addressable RGB lighting for those who want it, which is compatible with Asus Aura Sync, Asrock Polychrome Sync, Gigabyte RGB Fusion & MSI Mystic Light Sync.
The G1 is suitable for two 360mm radiators, with 11 G1/4 ports allowing the connection of a CPU and two GPU blocks alongside, with spare ports for refilling if necessary. The distro plate itself is made from transparent acrylic glass, offering an unobstructed view of the liquid coolant as it flows through the plate.
Stock should be available at the end of September and will be relatively limited in the beginning, so preorder now to avoid disappointment!
Lian-Li O11D Distro Plate G1 For High Performance Liquid Cooling Designed by EKWB @ £159.95 inc VAT
Distribution Plate for Water Cooling, Designed By EKWB for the Lian Li O11D and O11D XL, Includes DDC 3.1 PUMP, (L) 345 x (W) 131 x (H) 29 mm, ACRYLIC (BODY),
Only £159.95 inc VAT.
ORDER NOW
ORDER NOW
