This is a case I'm very excited about, the bigger brother to the A16/A17...Looks like Lian-Li's "stacker" with plenty of room for Watercooling.
Casing Dimensions and Specifications
Height: 595mm
Width: 220mm
Depth: 590mm
Weight: 9.5kg (net)
Material: Aluminum chassis
Case Color: Brushed Aluminum Black
Motherboard Support type: Micro, Standard ATX and Extended ATX
Drive Bays and Expansion Slots
12 x 5.25" External Drive Bays (1 x 5.25" to 3.5" Converter with FDD bezel)
9 x 3.5" Internal Drive Bays
Ports
7 Rear Expansion Slots
4 x Front USB2.0 ports
1 x FireWire (IEEE 1394) port
1 x eSATA port
Audio In/Out
Case Cooling
Fans
1 rear 120mm fan
3 x 120mm fans attached to HDD cages
Vents
Bottom meshed intake vent for PSU
Power Supply
None supplied
PSU bay supports Standard ATX PS2
Product Page
First Review: here
Second Review: here
Product shots
Height: 595mm
Width: 220mm
Depth: 590mm
Weight: 9.5kg (net)
Ports
1 x eSATA port
Audio In/Out
Case Cooling
Fans
1 rear 120mm fan
Vents
Power Supply
None supplied
Product Page
First Review: here
Second Review: here
Product shots
