Lian Li PC- O11 Razer Edition Build with first time water cooling
Love the build. This has helped me make up my mind to go for the Razer model over the stock model - think the RGB lighting is quite tastefully done :)
Great build, well done. Just a bit of friendly advice as I'm constantly re-jigging mine to get the best performance possible......
Personally I'd have the pump/res on the base and rotate it 90* clockwise so the tubes aren't pointing at side of case (of course) and put 2 or 3 fans fans as intake on the side where the pump was and 1 or 2 on the rear as exhast.
This is just to help the GPU and radiator get as much fresh cool air as possible, you could set the fan speeds to inaudible and they'd still be helping a lot.
Also consider having the pump IN tube on top of the reservoir.
It'll be very hard to fill the loop with the return path in the top. Plus air tends to travel back up the return tube in this arrangement when the PC is off.
Hmm good point, I don't have a pump/res combo so that's how I have to have mine.
