It's out there. If you're a froogler you'll find it...nam said:Hi,
As i am having great difficulty finding the V600B in the UK, does anyone know if i can use PC-60 instead for a Core 2 E6600 ?
Thanks
Snapshot said:The top fan extracts by default but I've set it to 5V and it doesn't seem to be doing a lot. The PSU is turned away from the HSF so isn't contributing to the airflow and I'd be a bit worried about not having any air forced towards the HSF. I might give it a try though the next time I have the case open. I'm about to order some more RAM for it so it could be this weekend.
nam said:i got the case today and found that PowerColor ATI Radeon X1950 Pro Extreme SILENT Heatpipe which i was recommended to get does not allow the the top fan to fit in the case
That card has the huge Arctic Cooling Accelero cooler fitted and it sticks up a loooong way.WJA96 said:If your fan is mounted outside the cage then put it inside the cage - otherwise your graphics card must actually sit well above the line of the rear expansion slots, which means that graphics card is not compatible with any Lian Li II series case that uses the Patent Cooling Fan. I really doubt that is the case.
Snapshot said:That card has the huge Arctic Cooling Accelero cooler fitted and it sticks up a loooong way.
WJA96 said:OK - The fan can go in 4 ways;
Inside the cage
-blowing in
-blowing out
Outside the cage
-blowing in
-blowing out
WJA96 said:Well, it looks like that's not going to fit.
WJA96 said:Try it for 24 hours without the upper fan. It may not make any diffeence. If it does then you'll need to return the card I guess.
nam said:any recommendations for a card that will fit ?
Look at the piccies of the cards. Anything where the heatsink doesn't extend above the top of the mounting bracket should fit e.g. the HIS and Sapphire X1950Pro's.nam said:any recommendations for a card that will fit ?
Snapshot said:Look at the piccies of the cards. Anything where the heatsink doesn't extend above the top of the mounting bracket should fit e.g. the HIS and Sapphire X1950Pro's.
nam said:have sent a email to shop to see if this can be exchanged. Anyone know if this is possible ?
