Lian li pc7 plus fans?
21 Mar 2006
Scotland
I was wandering if anyone knew the details about the fans that come with the lian li pc7 plus. The ones i got are black and 120mm in size. Thanks in advanced
I'm looking for some fairly cheap quiet ones for mine - any recomendations?
Sorry to intrude the thread ;)
I dont know if they are that cheap but the akasa 120mm ultra quiet 18dB fans are the best, i just wanted to know the dB of the lian li stock fans so i could decide if it were worth getting the akasas :D
ashmanq said:
Just looked at the silenx 14dBA 58CFM 120mm fan.. looks nice :D
Overrated specs tbh. :) Still quiet but there are others just as good (some are best at 7V/5V):
Panaflo L1/M1
Nexus
Acoustifan
Aerocool
Akasa Amber
Yate Loon
Aerocool do a 140mm fan you know they are ment to be very quiet,it come`s with a fitting kit so no mods are needed.
Just drop akaska ambers in, NOT the best but certainly the best in the price range and very quiet. I use two in my PC7 and honestly even with stock cooling on GPU/CPU I can't hear the PC.
