lian li pc7+
Mr Mister said:
With all that decent kit in there you should change the case!! Unless you want the wolf in sheeps clothing look.
I would but to be honest I really dont look at my comp that much. Also I dont want to risk blowing up my PC in the process (knowing my luck).
Thanks for the compliment though, and about the dust, its the just the top of the cards, the rest is relativly clean. But I do really have to clean the GPU fan, its getting really hot.
No it is not guaranteed, this crops up a lot, people have not had the 80mm version for 6 months+ and Lian Li no longer make it as far as I am aware, just they used up surplus boxes for some 120mm ones, meaning they all have to be sold as 80mm.
The odds of you getting a 80mm are very very slim indeed.
Its quite easy, I have my onboard powering my headset, used for BF2 and nightime gaming.
I have a Audigy 2zs running my HiFi for lan gaming and music/films.
Works quite well and only takes 2 seconds to right click my taskbar and switch which is running. :)
Always wondered how I can play games while I listen to music or net radio :) Everyone's quick to say Disable onboard audio because its not good so never bothered running both. Anyway, thanks :)
