Lian Li PCIE 4.0 Riser Cable
9 Mar 2021
Hey All
Anyone had any trouble with the PCIE 4.0 Riser cable from Lian Li? Installed new infinity uni fans into the case and had to switch to a vertical mount due to clearance.
As such I got the vertical mount for the O11 Dyanamic XL and the PCIE 4.0 Riser card for the 3090
The motherboard I am using is the X570 Crosshair Formula. Everything was working fine before hand but now all i get is a black screen and dont see any post code errors
Is this still an issue on X570 boards as it used to be a while ago?
