- 10 Oct 2018
- North West
Does anyone know when these will become available in the UK (or elsewhere)?
Feels like these are never going to appear, main reason I'm after them is my aio takes 140mm fans.
I have 2 clusters of SL120 INF in my case, but still using the stock Lian Li 140mm PWM fans, which are attached to 'full speed, but 4-pin headers' (blame ASUS for putting 1 PWM header on a X670E board). A final cluster of SL140 INF would be perfect to dial down the fans to low rpm and a consistently lit build.
Which one is that? My x670e-e is all pwm.
I noticed this as well, it's the same for others as well. I've had to end up getting them straight from the source elsewhere. Got their last 3 black 140s too unfortunately.
I was thinking the same. I know the SL V2 came in late but the wait for the Infinities is taking the mick.Can't believe these are not in stock anywhere yet its been a while since they were released.
It wasn't too bad, it was the cheapest shipping compared to other places. I bit the bullet since I want to get on with my maintenance/upgrade that I was planning on doing in January.I think i know where you got these, was shipping quite steep! I seen the white ones, was tempted
Yep also just bit the bulletIt wasn't too bad, it was the cheapest shipping compared to other places. I bit the bullet since I want to get on with my maintenance/upgrade that I was planning on doing in January.
2 x white on their way,
