Lian Li TR3 fitting advice
22 May 2006
I've bought one of these for my PC6 plus II. I have a few small questions. Its got 3 fan inputs (front\rear fan, cpu) and likewise 3 sensors (front\rear fan, cpu)
Firstly , the fitting of the HDD light wire. Everything is labelled except for the HDD light wire. There are two small jumpers above the power in, I guess this is where I connect the HDD ligh (from the mobo). Am I right, there are only two connectors left?
Secondly, any advice on how to stick the sensors? I guess the cpu one can be jammed into the heatsink. The front and rear temp sensors taped near the front and rear chassis fans.
Many thanks.
No need for the bump after a few hours, this forum does not move that fast and was still on the front page.
Wait for my editted response, please do not bump threads, they will get responses if someone is around who can answer the question.
HDD light goes on the two jumpers to the left, and the PWR goes to the right.
Stick them where you want with tape, although put each temperature sensor closest to the relavant fan.
AKA CPU fan on the TR3 is closest the fan connected to the CPU temp sensor.
Keep them in pairs as they are temperature controlled.
