Lian Li v1000+2 and Tuniq (pics)
H0wz3r said:
You're a mine of information aren't you! :p Thanks again for the tip. I'm not sure what you mean though, can you post a pic so I don't foul it up by getting it wrong?
All I wanted was to show a picture of the Tuniq... :) Just kidn
The Tuniq has a back bracket which fits behind the MB. You screw the four big screws into the back bracket (see assembly instructions).
Now, this bracket has some sticky stuff which is designed to stick to the MB in order to ease the assembly of the Tuniq. This sticky material is covered by a sticker which you are supposed to peel off before installation. Problem is that once stuck, it is very difficult to remove from the back of your MB. What I suggest is that you will not peel off the cover so it will not stick to your MB. The Tuniq will sit comfortably and does not know or care about sticking the back bracket, it is just something they did in order to ease the installation process.
Hope it is clear.
Hope it is clear.
Ah rite, I understand now. I'll leave the cover on the sticker then. Thanks for the tips and nice pics too btw :cool:
so glad i found this topic
some great info cheers taitai
i have the same motherboard, cpu and i am looking for a case that has good cooling - and looks nice - this might be the one
your cpu temps are mental, mine are 39c on probe with an arctic freezer 7 pro, with the fan full speed, can you remember your temps with the arctic freezer on this case?
so tempted by this case
