lian li v2000 and v2000 plus
rpstewart said:
In the plain v2000 the rails & dividers are rivited in, you could drill them out I suppose but it'll be a complete PITA.
Bah, more work!
I'll be hacking it up considerably anyway but I thought getting the bottom ready to take the prommie would be the easy bit.
Thanks mate.
The v2000+ has screwed in bottom hard drive rails as said.
There are other small changes, like the speaker but nothing really worth noting.
ArchAnGeL said:
Is Gray Mole doing that for you?
Make sure you post it when you're done?
Sure is. Sure will. :) Don't worry, i'll be posting loads of pictures of it when its done. Having Phase built into it is only the first step of for this rig. I'll be cutting custom windows, hopefully frosting a design onto them. Im also thinking about having the inside either powder coated or anodized.
I ordered a Lian V2000 and still waiting for it as they werent in stock though it says that it should only take 1-3days to receiv new stock. Anyone else waiting for their case?
ArchAnGeL said:
I would love to have had the money to get a new head and regass on mine but I am a bit strapped atm.
What mods are you having done to your unit?
Im having a system built from scratch. Nice quiet compressor, clear enclosure with LEDs drilled in, unseen controller, 404-402 gas blend, EL-wire running up the suction line etc etc. :D
I got my 2000 earlier this week, and got a pleasant surprise with it as well. When i ordered on the website is said that it was just the plain v2000, on the invoice it was changed to v2000+ and the case that i received was a v2000+II.
And I have to say that the case is beautiful, now i just have to wait another week or so before the rest of the gear arrives so i have something to put into the case :)
