Hey guys, putting a system together using the above case. Was hoping for some tips from others that have used the same case as I am not finding it that easy, being my first sff build.
How do I get the cdrom fixed, do I have to take the front panel and hdd cage out to get to the screws to fasten it in place?
I have the mobo and all componants on the tray but it's not easy to get cable access. Do you just insert the mobo tray and fumble around until all cables are in place or is there a better way. Not finding it easy at all.
This unfinished build is in danger or becoming a permanent ornament in my room.
