Licence help please
Great post rpmmatt, really good that.
What was London like to drive a lorry around, its bad enough at times walking round it
The very meaning of offensive driving, I was that bloke who took up double the amount of room and took up both lanes etc - loads of lads found it too stressful, I loved it but growing up in London did help.
Cheers @rpmmatt helpful post
@Josh I bet it was fun but I'm sure there were times when someone made a stupid move around you, like cyclists going up the inside etc
Do you guys have any tips regarding theory? I've got the newer book to help but do you find it easier to write stuff down as there is a lot :p
Practice, practice and practice some more - pretty much the same as how you prepare for your practical test tbh.
Look on the bright side, you can do it online these days, I spent hours reading the same Theory test book endlessly....
I'd be on this or similar if I were you mate.
https://www.safedrivingforlife.info...-tests/large-goods-vehicles-practice-test-one
I've been reading through the questions in the book I have, I know the answer to a fair few of the questions in the first section, any I'm not sure of or didn't know I've written down in a notepad..
Cheers bud I will look at the link and get practicing... I seen a post of yours about being back at work, hope it's not to quiet
Absolutely flat out at the moment, basically playing post lockdown catch up for a lot of customers, after this backlog is cleared though, I have my doubts.
lol
Our CPC training !!
A little question for you all, i'm currently reading through the theory book about braking systems and air lines.. It states about a Red line, YELLOW line and Blue line..
Could you please explain what line does what and are they always the these colours or do they change?
I found out what the colours mean but a more in depth explanation would be a great help
Red - Emergency
Yellow - Service Line
Blue - Auxiliary
Thanks
Red - Emergency
Blue - Auxiliary
Thanks
Ignore colours!
You go by airlines and electrical suzies as they are called, you have two airlines, one (usually red tbh) is your primary feed, your trailer brake MUST be on before you connect it, people think air brakes use air pressure to apply the brakes, in actual fact, the air pressure is what releases the brakes , which is why you'll hear of a broken-down truck with its brakes locked on, if the air pressure is too low, it simply won't move.
You'll soon see its the fittings that matter, not the colours (the "suzies" on my Scania are all black!) basically each line will only fit in its corresponding connector so you simply can't attach them incorrectly.
Two electrical connectors, one powers everything, the other, known as an emergency, is, as it sounds, a backup.
You also have an ABS connector, if the trailer has a corresponding socket to fit it, it MUST be fitted by law, the chances - these days - of hitching up to a trailer without ABS is frankly zero, and tbh you would not want to tow a non-ABS equipped trailer either!
Have a watch of this, it explains it better than I could. :o
Colour wise, Red is your primary airline (if its coloured at all) yellow is its return line (the braking system being a circuit if you see what I mean)
A video I highly recommend to watch is this on reversing an artic, the guy is spot on.
@Scania cheers bud some very helpful info there and the videos are great, I will watch the whole of that blokes video as he seems to know his stuff, love the way he does the reverse and then says 'that's it, easy' :p
In the book it also says if the trailer has a 3rd air line you do not connect it, why is that? :confused:
@Scania
In my (far too many) years of Class 1 driving, I am yet to encounter a 3rd airline - forget it - it crops up on international spec trailers as far as I know, really, don't stress on it.
Ahh that's good to hear then, one less thing to worry about while learning all this... Thank you
The technical explanation is
Airlines
  • Red = Emergency
  • Yellow = Service Brake
  • Blue = Auxiliary. Now redundant and no longer fitted
Electrics
  • Lights
  • Auxiliary (Reverse lights & Fog etc)
  • ABS
I tend to think of airlines as
Red = Supply
Yellow Activate
The Red charges the trailer air tanks and is the Emergency too.
Emergency..... When you pull the handbrake half on it rams air into the trailer brakes - This is known as "Dead Man Brakes"
ie: EVERYTHING FULL ON. No prizes for why it's called that !
When you apply the handbrake fully it RELEASES the air from the trailer & Unit rear wheels and the Spring brakes apply.
The air supply under normal conditions deactivates the spring brakes so if you lose air the brakes automatically apply.
Airlines
  • Red = Emergency
Electrics
  • Lights
  • ABS
Red = Supply
Yellow Activate
I had a feeling you'd provide a more technical explanation, cheers! :)
Our Rigid drivers earn exactly the same as the C+E Artic drivers.
There's a reason for that !
As Scanny states .... The Rigids WORK hard, LOTS of drops & Pump truck work.
I can't remember if I read it in this thread (I've just speed read through again) but the Turntable is called the "Fifth Wheel" because it carries a Fifth of the weight at that point !
Never knew that! I always assumed it was something to do with 4 wheelers... :o
@Minibiker
Watch this, then decide if this job is still for you.... :D
@Minibiker
:p he's a funny bloke... Some interesting points people have said to him about things that put them off truck driving.. It will take a lot to put me off though I think :p
Cheers @Outcast for those posts bud, very helpful :)
