- 1 Sep 2005
- Scottish Highlands
Looks pretty good unknowndomain. you may have already mentioned it, but what lights are you using there?
Bolerus said:the one i use at work was even cheaper
I made it myself
cut all the sides out of a cardboard box, covered the sides with greaseproof paper (i think 4 layers was what seemed to work just about) stuck to the carboard and other sheets with double sided tape
for the inside i cut some material that my missus had no use for and was goign to throw out.
bobs your uncles next door neighbours sister. a fully functional lightbox and no risk of any body snagging my credit card details
total price .. about £3
unknowndomain said:What are you referring to when yo say blown out what is the background the subject?
SteveOBHave said:Sorry - to explain myself:
Blown out I mean over exposed - too much light so you have lost some of the detail of the subjects (what you're takeing a photo of) i.e. the apple is so bright on the edges that you loose some detail.
My impression of what you desire from a light tent is controlled lighting to eliminate unwanted shadows and reflections - IMO (and it is only my opinion) you have a little too much light.
Please take my comments with a grain of salt - they are only an opinion/observation and I'm trying to be constructive.
This is the result I am thinking of:
unknowndomain said:I need to have a mess about. Its kind of a game of experimentation to see what works best, I used to use a light table with an infinity curve when I was doing a level photography and we would light to subject with 2 lights and illuminate the white plastic with another 2 lights, using a bowens quadx system it was very easy to setup so you didnt get the fringe overexposed because you could adjust the amount of light from each head seperatly at 1/4 stops i think.
Amp34 said:I actually quite like the over exposed look of the first couple of pictures, it makes them look dreamy and works well with the subjects you used.![]()
On the other hand I also like SteveOBHave's whose photos are more likely to be in an advert.
At the end of the day I suppose it all depends on what you are aiming for and what you are photographing.![]()
NorthstaNder said:These photo's are excellent and exactly what I am trying to achieve with my light tent when I'm photographing my eBay stuff.
I'm struggling with getting the nice crispt white backgrounds though. I only have 2 lamps and they are only 50w halogen spots.
unknowndomain said:You need much more light, mine are only slightly over exposed with full day light on a sunny day and 975w of light beaming down from 3 lamps.
