Lightroom pc
19 Feb 2008
Home
So after getting rid of my desktop PC and moving to a OK laptop I'm finding the laptop is not really that great at light room.
So I want to build/buy a small PC to go into my TV cabinet and its sole purpose will be light room.
I've looked at the minimum specs for a PC but as there are many togs who use light room what's the spec you would use to make the PC a capable machine.
TV used is 50" 4k.
Lots of memory.
Cores surprising dont matter which is a shame. 8 and 10 cores are no faster than 4 cores. Its all about cpu speed for max results.
the new AMD do very well and better than most Intel cpus but a fast overclocked i7 4 core gives the max results
https://www.pugetsystems.com/labs/a...15-8-AMD-Ryzen-7-1700X-1800X-Performance-910/
LR is screaming our for proper multi core use and also GPU use. an Intel gpu runs LR as fast as a Titan gpu atm.
Lots of memory.
New lightroom CC classic makes much better use of cores in some areas (exporting particularly):
https://www.pugetsystems.com/labs/a...CC-is-it-faster-than-CC-2015-1065/#Conclusion
Personally for minimum specs I’d go Quad core with 16GB RAM for my type of usage. A Q6600 might be a bit long in the tooth but certainly worth trying.
