Lightroom : workflows and organisation
13 Dec 2004
Stoke-on-Trent
I'm always looking for ways to improve my Lightroom workflow so thought I'd start a thread where people can share their workflow and their issues and maybe pick up some tips from other peoples too.
Mine is based on Weddings only and goes like this :
At the moment I create a new catalog for each Wedding. I like this system and understand that I could have a 2014 catalog instead but as there are two of us that do the editing and album designs, its important that we can both work on individual Weddings at the same time.
My current workflow :
  • Import images to specific wedding catalog
  • Flag images for client viewing using 'P'
  • Create Collection called 'viewing' and put all flagged images in
  • Client viewing - use star ratings to determine their favourites and to help me with the album design process
  • Create smart collection for different star ratings 3* to 5* (3* : chosen groups/formals, 4* : Client likes, 5* : absolute favourites, make feature of these
  • Create 'CD' collection and place 3*, 4* & 5* photos inside
My only issue is, editing an image in one collection changes it in all the other too. Not something I come across very often but for example I had to crop a shot for a Wedding Fayre frame I wanted to put up. This meant that the image was now cropped in all of the above collections. I still haven't found a way of using virtual copies that isn't messy and leaves me with loads of copies in my original folder.
It's not something I do and don't know if this helps but.. when selecting all the photos to create the new collection you check 'create virtual copies' to create all the copies (I'm guessing you've tried this) - after that you can then use the icons in the top right of the 'attribute' filter to filter out all the virtual copies when viewing the original folder.
i import all photos to a folder, then import that folder to lightroom (using a seperate catalogue for each job)
i use the star rating to flag them 1 = delete, 3 = keep and edit, . 4 and 5 = edited and ready
i then just select all 4 and 5 stars and export them.
I've seen that this morning. Never noticed that I could filter out virtual copies before, this could be the solution I was after thanks :)
I put my Wedding images in a Folder dated & named. I then open Lightroom and Import it. I then quickly look through and Delete what I don't want. I then Work on ALL the images in Lightroom & Photoshop. Saved as Tiff and Jpg.
...Insert sd card into reader which causes LR to open up automatically.
Press import.
Work on image(s) as required.
Export and print etc if necessary.
That's about it!
