Lightweight LAN Case
26 Mar 2008
As the title suggests I'm looking for a lightweight case that's easy to drag to a LAN. I really don't care about bling, I just want something cheap, cheerful and light. Only problem is that I need to be able to pack my dated q6600 ATX rig with a 4870x2 into it.
Was looking at these, but I don't know if everything will fit:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-184-CM&groupid=701&catid=7&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-045-LL&tool=3
Any previous owners of these cases have any advice or any other suggestions for cases?
If you only need 2 HHD the GMC R2 or R3 is a great LAN boxes.
You need to cut some 120mm holes in the base and back and have the HHD in the top position, next to the PSU.
It's no way near the quality of the LL's above but it's a third the price and has less volume that a A350 but still takes Full ATX mobo's and PSU.
As a cheap carry round case with a bit of LAN party intrest it's worth a look.
I'm useing the R2 in my current build as it was the smallest ATX case I cound find - lots of pictures of the inside in my build - the 4870x2 would be a squeeze but there a good 30-40mm clear on the right hand side of the mobo - can check for you if it's of intrest.
