Like stats - Sky Fibre Max
Jay
Jay
18 Oct 2002
North West
Recently upgraded from sky fibre unlimited to max. Download only syncing at 35. Anyone know if they notice a problem with my stats?
Router Statistics
System Up Time: 06:07:50
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time
WAN MER 15492012 8487522 10 7811038 227119 06:06:06
LAN Up 3930330 7452301 0 200964 7788865 06:07:50
WLAN (2.4 GHz) Up 195090 40739 0 8155 0 06:05:56
WLAN (5 GHz) Up 1481546 886749 0 633399 63441 06:05:54
Broadband Link Downstream Upstream
Connection Speed (Kbps) 34999 12000
Line Attenuation (dB) DS1:14.1 DS2:31.8 DS3:49.1 US0:2.5 US1:24.4 US2:38.6
Noise Margin (dB) DS1:14.6 DS2:14.6 DS3:14.6 US0:15.0 US1:13.2 US2:12.6
10 Oct 2006
The download connection speed of 34999 along with the headroom on the SNR makes it look like you are on a banded profile. It is going need a DLM reset to clear that and allow full line speed.
V_R
V_R
17 Jan 2007
UK
6dB is the default, XdB is only available if the line is good enough (ie not too much noise or crosstalk) and DLM 'turns it on' and its not available to ECI cabs and neither is G.INP (the last I heard anyway) as far as I know. So its not a given it will default to 3dB. :)
Jay
Jay
OP
18 Oct 2002
North West
Looks sorted. Openreach came reset line and fitted new filter
Connection Speed (Kbps) 67437 20000
Line Attenuation (dB) DS1:13.7 DS2:31.6 DS3:48.9 US0:2.1 US1:24.4 US2:38.5
Noise Margin (dB) DS1:6.3 DS2:6.3 DS3:6.3 US0:7.4 US1:6.7 US2:6.1
14 Oct 2007
newcastle
I would have still though you would get more than that, closer to the full 80mb actually, my attenuation is 15.6db and I get 75mb
19 Apr 2012
As his line has just been reset, DLM will take a little while to remove interleaving and if on a huawei cabinet, will settle down to a 3dv profile hopefully
V_R
V_R
17 Jan 2007
UK
Yep, interleaving is on by default on new profiles. All being well it should go away after some time, but that could be a few days or weeks, DLM is a strange beast.
26 Jan 2009
Salisbury, Wilts
Yes forgot some cabs are ECI based. All are Huawei around here so overlooked this fact.
Shawrey
