Limit to 1.5 gb/s Operation??
3 Jul 2005
ive just recieved my 250gb seagate 16mb hard drive, and at the back, its got a jumper to limit the drive to 1.5gb/s operation, whatever that means. If i take away the jumper I get 3 gbs. Surely that will be better?
Yes it will. Take the jumper off, but only if your motherboard supports SATA2 3gb. If it doesn't then leave it on.
well, I've a NF7-sV2 that works fine with these drives without the jumper, so I think the controler should auto it.
only take it off if your board/controller suports sata 2 ( 3gb ). where i work we have had a lot of problems with sata2 drives in a sata 1 enviroment. seagate ellected to have a jumper on their drives as default.
