Limiting Hardware?
May i ask whats wrong with the overclocking, didnt see anything drastic when i searched for "AMD Athlon 64 X2 6000+ overclocking problems" :confused:
There are no problems with it, its just intel chips are better overclockers atm.
or are there problems even with the correct equipment? :(
Yep its the current old tech chips that cause too much heat when overclocking, wait till the new 45nm AMD chips if your really want AMD :) They should run just as cool as the current 45nm intel chips, and hopefully similar performance.
