Line in (sound) issues
11 Dec 2003
Sol
Hey guys, posted this in sound city but then realised it was more for sound discussion, not troublehsooting, so thought i would plop it in here to see if you bright sparks had any idea! :D
Hey guys, i'm having some real problems and am hoping that you guys might be able to help shed some light on it, i've used my pc a lot in the past with the ps2 plugged into my tv card by composite, and the audio lines into an adapter then plugged into the line in on the sound card, or line in on tv card with the pass through to the sound card line in, never had an issue.
Got my 360 VGA cable last night and tried it today, phono leads into the supplied adapter to 3.5mm, plugged it into line in..nothing, tried it direct into the stereo, fine, tried with the other pc, fine, but nothing here, i have main input set as line in, but its not picking up a thing, ipod, 360, ps2, and i'm not sure why, all line ins are set at max and its set up as main device under "record" I'm using the onboard sound of a MSI K8 neo4 platinum, and i'm just not sure whats going on.
Just to check as its a format from july i didn't actually install drivers for the video capture card or tv card, i'm not using them, they're just sitting as needing drivers in control panel > system,if anyone has any ideas on what might help me overcome this, i would be really grateful!
Thanks.
T
