Linksys NMH410 NAS Problem
9 Jul 2005
High Wycombe
Hi All, not sure if this is in the correct forum but as its a NAS problem thought this was probably best.
I have a problem with my rather old Linksys NAS, NMH410. It stopped working through its normal webpage when Adobe Flash was discontinued but I could still see it as a network drive until last week on my old pc and mobile phone. The LCD screen has gone (likely the screen age) so I cant get into any settings but I was wondering if anyone knew how I could access the data on the HDD as its where I stored old photos and audio books?
I have tried connecting it to my PC, it sees it in diskmanager, but it seems its not formatted for use by a PC - any ideas how I can recover the data?
Cheers
Just giving ideas here, so do your research first.
From what I can see NMH410 uses ext3 for the drive format, can't be read in windows natively so you either need a linux distro or some sort of tool to read it.
EXT2Read seems to come up quite often but never used it.
https://www.ext2fsd.com/ is another one
This is a perfect example of why you should have more than one back up though...
very true, normally I do have backups I just forgot about this lot and was going to transfer it all over to a portable hdd, just never got round to it...
Will take a look at the Ext2Read, thanks for the steer
wow, it kind of worked, partly - its read the HDD, showed all the files and a load of system files, but nothing in the folders I was after - possibly there is some security feature that wont let me see them but when I copied over the whole set of folders, they were empty
