hi there last week i purchased a wrt54gl router from ocuk
i have my desktop pc connected through lan port #1 and my laptop is wireless with 128 bit wep enabled
the problem i have is the laptop is being used its fine - but if i turn on the desktop that is ok but then the laptop will keep saying cannot find page or it will take about 1 muinite to open a page that would normally open in 2 seconds.
i think the lan port is taking all the bandwidth
is there any way of sorting it out
i used to have a belkin and never had this problem it has only started since i got the linksys.
