27 Apr 2008 at 22:28 #1 Lord-Jaffa Lord-Jaffa Soldato Joined 29 Jul 2004 Posts 7,172 Is the above wireless router useable on adsl or is it a cable only router? Thanks!
27 Apr 2008 at 22:31 #2 snowdog snowdog Soldato Joined 27 Oct 2005 Posts 13,804 Location Netherlands it will work on any cable or adsl modem.
27 Apr 2008 at 22:31 #3 Dist Dist Soldato Joined 1 Jun 2005 Posts 5,152 Location Kent More of a question for the networking section then GD.
27 Apr 2008 at 22:31 #4 Spyhop Spyhop Soldato Joined 16 May 2005 Posts 6,509 Location Cold waters Yes, but you would need a seperate ADSL modem between the phone socket and the Linksys.
27 Apr 2008 at 22:31 #5 Hamster Hamster Soldato Joined 25 Oct 2002 Posts 5,648 Location location: location Cable only. edit - as standalone. (Also there is a networking section of this forum).
27 Apr 2008 at 23:23 #6 Lord-Jaffa Lord-Jaffa Soldato OP Joined 29 Jul 2004 Posts 7,172 yeah sorry i meant to post in the networking bit
28 Apr 2008 at 10:02 #7 Clairvoyant Clairvoyant Soldato Joined 19 Oct 2002 Posts 6,580 Location Torbay, Devon, UK I used mine when I was with VM (cable), and I am now using it with ADSL. I just purchased a AM200. Works fine. I use Tomato firmware.
28 Apr 2008 at 10:10 #8 FrenchTart FrenchTart Man of Honour Joined 16 May 2005 Posts 31,297 Location Manchester It's not really 'standalone' even with cable - it'll still be using a cable modem
28 Apr 2008 at 15:03 #9 bledd bledd Don Joined 21 Oct 2002 Posts 46,859 Location Parts Unknown Clairvoyant, Did you just configure the modem using ethernet, then once you got the connection live, plugged directly into router? Then in Tomato on the wrt54gl, you set the ip address to fixed..? Considering upgrading my mum's home connection to a wrt, as thats what I've got now on my ntl
28 Apr 2008 at 18:15 #10 Clairvoyant Clairvoyant Soldato Joined 19 Oct 2002 Posts 6,580 Location Torbay, Devon, UK The modem should find an ip adress its self (DHCP enabled). Set the router up via ethernet for wireless. Then just log on via laptops etc wireless. It generaly has most of the setting set as standard. Its only the wireless info I set WPA / password etc.
