- 27 Jan 2005
- S. Yorks
Am trying to use LIQ to populate dropdown lists and also a gridview, been following one of the many online tutorials and come up with the following:
As this is just a test to see how to work with LINQ I am trying to return the entire table to a gridview, the problem lies in that nothing gets displayed to the gridview and I am not sure why?
I can see that CCArea contains 3012 rows, so it has the data, so it must be something to do with the next two lines.
Do I have to populate the datagrid with columns prior to binding the datasource or will the columns autogenerate?
Any other ideas?
Matt
Code:
CCDataContext db = new CCDataContext();
string connectionString = System.Configuration.ConfigurationManager.AppSettings["ABPConnectionString1"];
db.Connection.ConnectionString = connectionString;
var CCArea =
from c in db.tbl_CC_AreaInfos
select c;
GrdDynamic.DataSource = CCArea.ToList();
GrdDynamic.DataBind();
Any other ideas?
Matt
