Liquid Advice required
28 Sep 2011
Hello everyone,
So over a year ago i built my pc using EKWB products and Mayhems pastel white liquid with purple dye.
I am currently thinking of rebuilding the pc and looking into using Mayhems XT-1 purple nuke. But im wondering will the my EK nickel waterblocks will react to XT-1 nuke or will i be fine?
This is what pc looks like atm: https://imgur.com/a/2izLSdz
If you do that then it works out much more expensive than if you just bought X1 in the first place. I have never had any problems with X1. The only nickel plated items in my loop are some nickel plated fittings and they look just like they were when new.
From Mayhems X1 product page:-
Blended with non-toxic corrosion & scale inhibitors for protection of Copper, Brass, Steel, Nickel and Aluminium.
Yea price wise it would be more expensive but im bored of pastel fluids and want something clearer if that makes sense.
