Liquid compisition
Can't see properly in the picture, but here ( http://www.imageupload.co.uk/IWC ) the bottom fitting coming out of the res needs an extender on according to the manual posted by GiraffePencils. You can't use a Monsoon fitting directly on the port since the o-ring won't compress properly.
Well, in you pic you're using the res port #3 which requires an extender which is included in the res packet if you buy it new, I quote again:
"IMPORTANT NOTES:
1. When using ports #3, #4 or #6 it is mandatory to use the enclosed EK-Extender G1/4 (EAN: 3831109845165) due the ports being recessed into the plastic
Reservoir Bottom."
EDIT Kaku beat me to it
"IMPORTANT NOTES:
Reservoir Bottom."
Basket please for the extenders?
