- 22 Jul 2009
- United Kingdom
hi guys might aswell start with system spec,
i7 3770k @ 4.1
asus sabertooth z77
asus strix 970
8gb corsair vengence
corsair HX1050
2 random 1tb hdd
1 250gb samsung 850
windows 10
xb271hu monitor
so the problem started when i got my new monitor and new 970 kept having "No Signal" errors after much trial and error i found out that it was the overclock on my monitor causing the issuse turned if off and worked fine.
few weeks later was playing gw2 and all of a sudden "No signal" so restarted pc and pc kept saying "No Signal" usually this would get me back to windows and all would be fine for a while, so tried old monitor still "No Signal", tried 970 in another pc and low and behold "No Signal", so RMA'd GPU fault was found and they replaced it (woop).
finally got new gpu put it in pc and windows 10 wouldn't load ... just kept getting stuck on the spinning circle, formatted pc new install of windows 10 working fine untill it updates its self and installs "Intel 4000HD driver" pc would freeze try to reboot and it goes to black screen and usb mouse/kb are dead, change setting in bios to on board gpu and it works fine windows loads disable "Intel 4000HD driver" in device manager and it works fine with gpu again.
is this issue cause by my new 970 ? cause i really dont want to go through all the hassle of RMA again or could all this just be a coincidence ?
i7 3770k @ 4.1
asus sabertooth z77
asus strix 970
corsair HX1050
2 random 1tb hdd
1 250gb samsung 850
windows 10
xb271hu monitor
