Little Triangle
6 Dec 2019
Hi I’m looking for a way to connect old hard drives (various types) to check for data before throwing them out.
I don’t have all the the cables etc… however I found this product that might be useful ….
Little Triangle™ Pro Converter – Little Triangle LLC
Is this a good buy ?
Thanks
Viper10
Corsair Graphite 600T Case
MSI B550-MAG (Socket AM4) DDR4 ATX Motherboard
AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail
Patriot Viper Steel 16GB (2x8GB) DDR4 PC4-28800C17 3600MHz Dual Channel Kit
Powercolor Radeon RX 5700 XT Dual Fan 8GB GDDR6 PCI-Express Graphics Card (top PCI)
Crucial P5 Plus 1TB M.2 PCIe x4 NVMe SSD/Solid State Drive (top location)
Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB
Seasonic Prime Ultra Snow Silent 650W 80 Plus Platinum Modular Power Supply
Arctic Freezer 34 ESports Duo White CPU Cooler - 2 x 120mm
Dell2311H Monitor (Display Port)
No, can get it cheaper. Go look at the rainforest and you'll see the same thing with a different name by multiple brands.
What is the rainforest ? Do you have a link ?
What would you recommend ?
Thanks
Re the first part, you can't link other websites that sell things on here as this forum is linked to Overclockers so, understandably, advertising any competition isn't looked upon kindly.
I think all of my enclosures are Sabrent, I have a 2.5/3.5 drive caddy and an nvme enclosure. They do the job, they won't change your life but they work.
