Live Far From the Exchange - Will an Arial Help?
Well you'll be able to pick up tv broadcasts to entertain you while you wait for pages to load, so yes, in a way![]()
two miles isnt far considering the electrical signals in a twisted strand or coaxial internet wire travel at almost the speed of light
thats 200 000 000 m/s
thats 200 000 km/s
and thats 1260 000 000 km/h
im just getting that info my my gcse physicsExcept that all the different wavelengths travel at slightly different speeds, so the quality of the signal deteriorates over distance.
Hi Please could explain a little more about this, i just have an adsl where the router and phone line is plugged into?Try using the test socket, remove the faceplate of your master phone socket and theres a test socket hidden underneath. Plugging your modem or router into that is about the limits of what you can do.
I live 6km from the exchange and get 3.5 MBit/s this way.
not sure about this, I can envisage different attenuations for different frequencies but never heard about different speeds, do tell more
We got that bit, you put it in the OP. We're asking where it's plugged in.
