- 20 Oct 2007
- South Yorkshire
Recently along with my new system i ordered a Belkin F5D7051UK Wireless adapter to work alongide.
http://www.overclockers.co.uk/showproduct.php?prodid=NW-071-BE&groupid=46&catid=1002&subcat=
At the end of the installation it should pop-up with a window saying that i can plug it in however at the end it did not show such a message.
Once i double click the program on my desktop nothing happens and the same goes for the shortcut in my start menu. If you go into the directory or go to the task manager to run it would come up with a message saying "Load Library <0000> Broadcom.dll fail!".
I am currently running Vista Home Premium 64-bit.
My first guess would be that it is incompatible with the OS.
My second guess would be that it does not work as when i plug it in no light come up on it however i also own a 54Mbps version which lights up when plugged in. When i plug them both into each of my two Laptops USB ports the same happens.
Any help much appreciated
