Load Line Calibration help
23 Mar 2007
Essex
Evening all i have finally got my 3.6 OC stable at 1.42v but the question i really would like answered is what does "Load Line Calibration" actually do and whats the best setting for it. In my bios i have the option of auto manual and disabled, at auto its saying Load Line Calibration is running at 51% i have red different stories with regards to this setting and im kinda confused.
For example my 3.6 OC has a bios setting vcore of 1.42 and when i tested under prime for 12hrs i had a min vcore of 1.32 and a high vcore of 1.45, this really is quite a big difference from the 1.42 i set especially the point where it hit 1.45
Would like to hear people views on this setting and how you go about setting it up
I know i have been told that before but im really interested in how other people go about using the setting as everyone seems to have a different opinion of it
LLC only affects the voltage when the CPU is on load. So it will still drop normally when its idle. I have it on auto for my OC but you can put it on manual if it causes you any instability
I think all we AMD owners know the magic number here is 19% - HOWEVER - Some boards like mine also, do not give an option to set percentage for LLC - only options are AUTO, ENABLED or DISABLED!
