Loan question
Get £1500 banger with 12monts MOT. You will need the rest of your money to be able to afford holidays when the world is back to normal next year :)
I thought this info might be useful. I once helped write the loan quotation software for a bank. It was back in the mid 2000's now so things might have changed a little. But there are many factors which go into the quote. It's not just your credit rating. But there are calculations made about the type of person you are. e.g. how likely are you to default on the payment, how likely you are to repay it early, how likely you are to refuse the loan at a certain APR and how likely you are to take a loan from a competitor. So if you keep paying loans back early then the next time you take a loan your APR may go up slightly. That's because the company wants to get the most profit from you early in case you pay it back. Loan quotations are actually quite complex. All of these factors were calculated at each APR rate and then the most profitable APR offered to you.
e.g. Between 2.9% and 15% in 0.1% increments all of the above factors (and more - I've forgotten most of them) are taken into account to calculate the profit. Then the APR with the highest profit is chosen at the end of the calculation and offered to you. They did also factor in the likelihood you were to take loan protection insurance but I assume that's no longer allowed.
The only thing I can think of as a possible issue is that if the loan is given very specifically and solely for the purpose of buying a car then by a very strict interpretation you might be considered to not be complying with those terms if you borrowed £8K specifically and solely to buy a car and used £2K of it for something else. Maybe. Potentially.
It's likely an unsecured loan, you can tell them you're buying a car with it (if they even ask anyways), then go and blow it all on cocaine, as long as you make the payments as scheduled they wont care.
It's a minefield to me. Not sure what to do now. I either except it for what it is at 15% or risk affecting my credit score by looking elsewhere.
My credit was bad around 10 years ago, but it's been on the increase since sorting everything out over 5 years ago. No missed payments on my credit card, no defaults, no CCJ etc.
I've checked credit karma and there's been no new hard searches on my file so that's a good thing I suppose. Theres numerous soft searches, but it says that doesn't affect anything.
I'd look for something £6k cheaper rather than pay nearly 16%.
I agree. I don't want to pay that much to borrow it
OP I wanted to come on here and berate you for asking more than one question. But you have, indeed, asked a lone question...
I spoke to someone really helpful at NatWest this evening. He said the higher interest rate of 14.9% is due to not having a loan before and my credit report is relatively simple in regards to borrowing money.
He did explain being able to re-finance the loan in around 6-12 months which should be a lot lower APR. (Assuming I keep up with payments and my credit file doesn't go down).
Don't listen to him. He is banking on you not doing that and there is no guarantee it will be the case. He will have already taken his commission. And everything he told you is just a guess. He has no idea.
Do you have a credit card?
So I tried Sainsbury's as they had the lowest advertised APR. They said no for whatever reason.
I signed up to a credit check to see what was going on and that showed my credit to be good. Was something like 7/10.
They gave Sainsbury's a 30% chance of acceptance, but NatWest (who I bank with anyway) 95%.
(Should have checked first I suppose).
I ran through the calculator and they gave an APR of 3.9 I think it was. Ran through the quote and it's now gone to 15.9%. NatWest said they can't change that, but it won't affect my credit if I wanted to look elsewhere.
Is this normal for the advertised APR to change?
If I check elsewhere, does it affect my credit score every time I get a quote?
It seems like I need to get a quote to know the true repayment
7/10 is bad imo.
You will never get the advertised Apr with that score. You need 9/10 minimum. I'd say 10/10 personally.
They offer the advertised Apr to just over half the people who apply. The other half get much higher and that's where they make their money.
It's a shame that at 35 I don't understand this more. But I suppose as I never had a loan, I never cared
You need to go on money saving expert and bookmark it and read the correspondence section whenever you are doing anything to do with finance or big costs / bills.
https://www.moneysavingexpert.com/loans/
There is a lot of stuff on there. It shouldn't just be a quick 5 minutes of flossing over. It should take you several hours or even days to go through depending on your current level of knowledge and ability to absorb information and process it.
Personally if I were you. I'd just buy a cheap honda civic or a Toyota Corolla. Both cars are pretty much low maintenance and bulletproof and cheap to repair as well as simple to repair.
Keep your current car and run it into the ground, don't go down this route especially if its just because you fancy a change.
If your credit is good then the APR should be under 3% on any over £7500 and try to reduce the term to 4yr as that way you will pay even less interest.
Then take it and then make a lump sum over payment and either select to reduce the term further or monthly payment as they normally give you that option.
