Firstly apologies for the long post.
I have an issue with a tree outside my house that is not on my border.
Recently the drains to all the houses on our section got blocked, the water board came out and cleared them but in the process of this they noted that tree roots had penetrated the pipes in locations (they had put a camera down to have a look).
Additionally late last year I had noticed cracks beginning to appear in the tarmac and concrete both on my drive and on the pavement outside my house. I had a council inspector come and look and they blamed this on the extreme cold the year before which I accepted, rightly or wrongly.
However recently the cracks have been getting worse and again 2 weeks ago the drain blocked up again. Yet again the guy that unblocked them said that the roots were causing a major problem, not only with the pipes under ground but with the surface as well because the roots are physically moving the pipes.
So to show you what I mean:
The tree in the middle is the one the water board say is causing the problem. The bottom right hand of the photo is my drive, everything to left of my front wall (on the right) is not my border and therefore I presumed the council's responsibility. The drain that keeps blocking is in the middle of the road near the blue Peugeot.
You can even see the cracks on the surface I'm talking about in the photo, a couple of years ago they were not there.
So I ring the council last week and they agree to send out a tree inspector, today I get home from work to find this response in my post.
Now I'm baffled by that reply. The council mow the grass that surrounds that very tree, they laid a new surface of tarmac not 3 years ago on the pavement outside my drive, those wooden posts you can see sticking out of the ground were installed by the council 3 years ago. 2 years ago they even pruned that exact tree in the summer.
So I'm a bit stuck as to what my response should be if I'm honest. Is there anybody here that could some advice on what my next move should be.
Any help offered would be very appreciated.
