Logitech G Hub - a piece of crap
  • Thread starter Thread starter Deleted member 651465
  • Start date Start date
I use ESET Smart Security (with Defender still doing periodic background scans) and I never see anything about allowing any processes during install.
I wonder if you went bareback (drop all security features/firewall (unplug Ethernet first as you can use the offline installer 32bit and 64bit choices) and installed and rebooted (plugging in cable) it would it work then.
What do you mean offline installer? Doesn’t the installer just download the latest files online?
Not 100% sure but the universal installer "lghub_installe.exe" is only 35MB so it downloads the full 32bit or 64bit driver for you (depending on your OS).
The offline installer does not seem supported now (read on their Twitter), claims it needs a connection to do update during install.
How about grab an older version that worked for you and hope it lets it install as older version then updates, not updates during install.
Logitech G HUB – Logitech Support + Download
  • Software Version: 2020.4.47660
  • Last Update: 2020-06-10
I cannot install this piece of crap software :mad:
Did a reformat recently and cannot get past the install logo animation. It just sits there spinning and spinning.
Anyone had this issue? I’m running a light speed G502 and G915 TKL which I’ve had working previously.
A fresh install of Windows 10 with ZERO updates, ALL windows updates, no drivers installed, ALL drivers installed, new installer, old installer... nothing works. I’m totally stumped.
All the advice I’ve seen says to reinstall but that’s not worked. As far as I remember from the last known working install was that it should prompt for a windows firewall acceptance but it doesn’t. Forcing it through the firewall hasn’t fixed anything so :confused:
had the similar issue. download latest microsoft visual c++. If it wont help try previous one
Like I’ve said... I’ve already tried that.
Ive gone back and tried ones I know work (literally the last update) and ones a few months older. Nothing.
I shall try installing visual C++
Advise you use these as full up to date packs (amazing what programs and games can randomly crash due to these not being up to date).
[Repack] Visual C++ Redistributable Runtimes [2020-10-10] | My Digital Life Forums (mydigitallife.net)
If you do not have an account use Guru3D forums for same thing.
or direct
https://pastebin.com/raw/46rfrtBv
Releases · abbodi1406/vcredist · GitHub
- AIO Repack for latest Microsoft Visual C++ Redistributable Runtimes, without the original setup bloat payload.
- Built upon VBCRedist_AIO_x86_x64.exe by @ricktendo64
- The process is handled by a windows command script, which runs hidden in the background by default.
- Before installation, the script will check and remove existing non-compliant Visual C++ Runtimes, including the original EXE or MSI setups, or older MSI packages versions.
- The uninstallation option/script will remove any detected VC++ runtimes (except UCRT).
- Windows XP support is partial, the pack will install and detect latest runtimes versions, but it will not check and remove non-compliant versions.
- You can extract the installer file with 7-zip or WinRar to a short path, and run Installer.cmd as administrator
- Visual C++ Redistributables (x86/x64)
2005: 8.0.50727.6229
2008: 9.0.30729.7523
2010: 10.0.40219.473
2012: 11.0.61135.400
2013: 12.0.40664.0
2019: 14.28.29325.2
- Visual Studio 2010 Tools for Office Runtime (x86/x64)
10.0.60833.0
- Legacy Runtimes (x86)
Visual C++ 2002: 7.0.9975.0
Visual C++ 2003: 7.10.6119.0
Visual Basic Runtimes
- Universal CRT:
complementary part of VC++ 2019 redist.
inbox component for Windows 10.
delivered as an update for Windows Vista/7/8/8.1, either in Monthly Quality Rollup, KB3118401, or KB2999226.
installed with VC++ 2019 redist for Windows XP.
this repack will install KB3118401 if UCRT is not available.
- VC++ 2019 runtimes are binary compatible with VC++ 2015-2017 and cover all VS 2015-2017-2019 programs.
@ricktendo64 / MDL forums - repacks.net - wincert.net
VBCRedist_AIO_x86_x64.exe creator, modded MSI installers
@burfadel / MDL forums - @thatguy91 / guru3D Forums
original installation script
Visual Basic and Visual C++ are registered trademarks of Microsoft Corporation.
I've just built a new systemm fresh install of Windows 10 and installed it just fine.
I'm on version 2020.8.5950
Hardware; G502 mouse, G512 keyboard, G933 headset
Update. Installing C++ didn’t work.
I looked at the suggestions on Reddit had success installing with the 2020.01 exe but as soon as I updated the software it would get stuck in the same loop :rolleyes:
Normally you’d say “so don’t update” but it doesn’t even recognise my keyboard on that old revision; so I have to.
Really lost for words now. Literally nothing had changed from the last time it just won’t let me use the app.
thats bummer. just checked the apps and on the day when i had logo loop issue i intalled c++ 2012 x86 c++2012 x64 and c++ 2015 x86 from microsoft website. Try all of them pls it must work
Have you got any USB items plugged into the computer that you can remove ?
Also do you have a PCI-E sound card ? or any other PCI-E card apart from a GPU ?
