I've been using a Logitech MX518 for years and its my preferred mouse. But since using it on a new Sandybridge 2600K Asus Mobo combination I feel that its pausing briefly on scrolling and mouse clicks.
It could be Win7 64bit affecting it also. I'm not sure. So unless anyone has any suggestions what would you suggest as a replacement that is very similar in feel.
An additional thing I'm noticing is I seem to be missing key presses when typing on my Logitech Media Keyboard (wired) Key presses don't register all of the time.
I dont use setpoint drivers. Both mouse and keyboard worked fine in my previous system using a LGA775 Mobo on WinXP 32bit.
Are there settings within Win7 64bit that may make a difference to the problems I'm having?
Both are wired and use the PS2 ports not USB
