- 21 Apr 2013
Hi. So basically my brother is getting a Gaming PC and it will be going in his bedroom, the router is down in the study downstairs where my PC is, ideally we would like to get him a wired connection but that means getting a very long Ethernet cable up the stairs along a doorway and in to his room without getting in the way so I'm thinking that's going to be a little tricky. I was going to put it along the skirting board and just use some tape to keep it in place but not so sure my mum will like that idea.
Are there any other practical bits of kit out there that would make it look a bit more presentable and do a better job than some tape?
We were going to use some wireless adapters but he has used them with his PlayStation and it gives him an awful connection, not sure if it's the product or that it's on a different circuit so we thought it would be better to try and go the long Ethernet route.
Are there any other methods you'd suggest that aren't very expensive that I'm missing?
Any help would be appreciated.
Cheers.
Cheers.
