Long overdue first build
15 Jan 2009
Thailand ATM
I finally went ahead and built my first rig! let me know what you think.
CPU i5 3570k @3.4
GPU Sapphire 7970
MB ASUS P8Z77 V
RAM Corsair Vengence 16GB 1600MHZ
SSD OCZ VERTEX 4 128GB
HDD WD 1TB Green
PSU Corsair GS800
CASE Corsair 300r
I starting to get concerned about my PSU, the fan is never on. Doesnt feel hot to the touch. Do i need to plug it into the MB?
From the Corsair site
Quiet Operation
"A good gaming power supply must provide the cooling you need when you're pushing it hard, but it should be quiet when you're not. GS Series PSUs accomplish this through excellent efficiency — it generates less heat, so it requires less cooling — and a temperature-controlled 140mm fan that automatically adjusts its speed to meet demand. It doesn't even spin up until it's needed."
