- 18 Oct 2002
- Bamber Bridge
Hi all,
I'm currently running the following system:
Core something or other 2140 - 1.6ghz
74Gb raptor drive
4gb ddr2 corsair ram
various other sata drives ranging from 120gb to 640gb
Intel motherboard, Nothing special all on board matx job, based on 945 chipset.
Akasa eclipse 62 case
iiyama 17" Prolite E431s
256 nvidia 7800gtx
Hiper 650w modualr psu
Now i'm looking to upgrade as i'm wanting to cut down on the number of external drives i've got. But main uses for PC are:
VMware for testing, I use MDT, WDS, server 2008 R2 to help with MCITP studies and test things for when I try it at work.
Media server to stream to PS3
very light gaming use, well not really any games now as I use PS3 for gaming.
Now i've been looking at having the following items to upgrade machine.
Asrock Z68 Extreme4
Core i5 2600k
8gb ram
or just buying a HP Microserver. Can anyone help with what I should do? i'm not too bothered about boot times due to fact machine is very rarely switched off, only rebooted for software installs and updates. Things i'd like from the system are, 8gb ram, gigabit lan, either single or supports teaming and 8 sata ports. Ability to run VMWare, ESXi would be a bonus then I can run WHS in a virtual machine. I've got a lot of large vmware files, made a copy of servers at work to bring home for testing purposes and each one is about 250-300gb, and there's maybe 10 virtual machines, only have about 4-5 running at once.
Budget will be around £500ish. Mainly looking to change mobo, cpu and ram and buy a couple of 2tb drives. Been looking at i5 but am open to AMD offerings, but i'd like it to last a good few years, current bits are between 3 and 7 years old. Or do I just look for a quad core 775 chip and mobo with lots of sata, gigabyte P35-DS3R has 8.
TIA
Ste
74Gb raptor drive
256 nvidia 7800gtx
Asrock Z68 Extreme4
Core i5 2600k
8gb ram
TIA
Ste
