- 11 Mar 2006
Hi,
I am looking to set up a wireless connection between a friends house (around 350-400m away) mainly because he can get broadband and i cant... lol
I will be using this antenna : Netgear ANT24D18 18dBi Directional Antenna,
apparently with a range of up to 10miles.
I have 2 installation options, the easiest one being for me to install the antenna in his loft, this would mean the signal travelling through 1 wall, trees and then an open field for 300-350m. Would this work?
If not, i could install it in the top of the tree, meaning the signal would only have to travel across a flat field for 350m.
Also, do i need a particular antenna to receive the signal at my house or i can i just use my current belkin PCMCIA wireless card?
Lastly, does anyone know of an ISP that comes with a free wireless modem w/detachable antenna/compatible with the Netgear ANT24D18 18dBi Directional Antenna? If not (bit too specific
) which wireless adsl router could i use?
Any advice would be greatly appreciated
AMD
.I will be using this antenna : Netgear ANT24D18 18dBi Directional Antenna,
) which wireless adsl router could i use?Any advice would be greatly appreciated
AMD
