Ok so my little Meriva is coming to the end of its time
Its got a small coolant leak some were, its got intermititant boost issues and the ECU light is flashing on and off aswell.
So it has some big bills heading its way unfortunalty
To be fair I've had it 2 years, it cost me £900 and its done everything thats been asked of it and more.
I'm moving in the next couple of weeks and shortly after that I'll be car hunting.
My only criteria car wise is that it is -
A Diesel (Sp sorry)
Has Air con
Is roomy inside
Isn't expensive on tax (£145-180 tops)
Isn't to expensive to insure/service etc
Cost no more then £5,500 - this isn't optional or flexiable I'm afriad
Update - should have added this aswell. Doesn't have a low driving postion - more step in to, then step down into it when getting in
My current thoughts are the following
1 - A newer Meriva
Its just a nerwer version of what I have now and I'm ok with that
2 - A Golf Plus
A bigger version of what I have now, Seem's to get good reviews and has reasonable kit - Plus DSG is avilable which wouldn't be a bad thing
3 - A Touran
Might be bigger then I need really?
Reason I'm looking at these is I am bigger guy and I want something I feel comfortable in and has room for my few friends to jump in aswell. I also want to do some driving around the UK, get to see the place etc hence the diesel.
A Diesel (Sp sorry)
Has Air con
Is roomy inside
1 - A newer Meriva
2 - A Golf Plus
3 - A Touran
