Looking for a 1440p gaming monitor not sure what to get does anyone have any advice.
6 Jan 2021
Hi I’m looking to upgrade one of my monitors I have 3 Asus PB278Q but they are getting a bit old now but still are great for my work, but I would like to upgrade one of them for gaming.
So, I’m looking for a 27inc, 1440p with 120Hz or higher and g sync or freesync would be nice.
Any advice would be much appreciated
Thanks Rob
Probably would be looking at the Dell S2721DGF or the LG equivalent (27GL850?) You could also consider the 240Hz Samsung Odyssey G7 though it is pretty curved. :)
Using the previous Dell S2719DGF. Pretty good, despite being a TN panel.
The new S2721DGF should be even better, as it's faster and IPS.
thanks for the advice I was looking at the G7 but I was trying to get an IPS if possible the S2721DGF looks good I will look into it.
