- 26 Aug 2005
- London
I've been looking around trying to find out under budget - £2500 and am having no luck. Any places you can recommend? I've tried the usual - Ebay and Autotrader but nothing.
[TW]Fox said:Look for a petrol one instead - if you dont do high mileage the savings buying the diesel wont be much, if you *do* do high mileage you dont want a citycar anyway![]()
POB said:The slight issue is the JTD is much better then the petrol ones though.
panthro said:I beg of you please do not buy a Punto. Please.
But what he's saying is, a diesel will only save you substantial money (if any) if you do probably 20k a year upwards, and if you're doing that kind of mileage, i know i wouldn't want to be doing it in a tinny, unreliable FixItAgainTomorrow city hatchback.
Smiley Man said:you driven one? or been in one for long periods of time?
one that has a decent engine that is
- due to a jubilee clip flying off the bottom of radiator)- don't be put off by the usual comments re fiats. check out: www.fiatforum.com and www.puntomk2.com for any enquiries re: puntos
Chris1712 said:Well i've been a 1.2 for about 20 minutes, and last time i checked build quality and interior comfort doesnt go up with engine size (exception of leather obv). It felt like a tin can, didn't feel overly stable at 70mph and by gosh it took its time to get there. The JTD engine is a very capable engine, a mate of mines dad has one in his duplo and heaps praise on it. But when your doing high enough mileage to warrant a diesel engine, surely one in a better comfier car is a better choice.
EDIT: this was a 51 plate btw.
I take it you mean JTD Multijet thereSmiley Man said:that'll be why then, have a go in one with a proper engine (100bhp JTD lump) and see what ya think![]()
Smiley Man said:that'll be why then, have a go in one with a proper engine (100bhp JTD multijet bells and whistles super duper lump) and see what ya think
feels solid at 70, and not bad at 120 on our private runway with no children and kittens in sight![]()
.Chris1712 said:Why would the engine make a difference to its suspension/chassis feel at high speed.
Smiley Man said:the diesel (especially the HGT) is gonna have stiffer suspension
i can assure you the 1.9 HGT feels planted at 70![]()
dilated said:i drove a mates 2/3 year old hgt and that didnt feel great on the motorway, i doubt the uprated suspension would make a lot of differance.
it was easy to park though - so my missue would love it.![]()
