Looking for a pipe key on my laptop?
16 Jan 2006
Internet
Hi
I have a laptop and I need to use the pipe key in the terminal and for some reason, I can't find it on my keyboard. Done a few google searches but nothing is coming up that helps apart from programming the terminal to map the key.
I will be using a lot of different servers so atm this is a final resort.
The key I mean is " | " (copy and paste it before someone asks you have already typed it hehe)
please find below a picture of my keyboard - the laptop is an Acer Aspire S 13
nope tried that one thank you. tried that key with both control keys alt keys and alt gr and yeah its very annoying. I love this laptop too!
It's an US keyboard layout so you need to set it as that and then the key above the enter key should do it for you (shifted backslash).
What Feek said - you may find it listed as one of the "English (US)" variants. Setting this in your desktop environment's settings panel should do the trick, but there is the rare chance that your terminal program fails to pick up that setting, so you might have to google how to set that if that is the case (I've seen this once before).
I'm currently typing this on a English (US) keyboard and I can type | (pipe) using that key across my desktop programs including gnome terminal. Keep the English (UK) setting as an alternative profile though, otherwise you'll find typing "£" gets to be rather tricky.
