Looking for an XSD editor
18 Oct 2002
Surrey
with similar functions to XML Spy but as an open source (or free closed source) application. I've been using Visual Studio, but it's so pap it's unbelievable.
I wish I had the time to write one....
Paul
Hi,
An Eclipse plug-in called XMLBuddy might be worth a look. The Pro version, which I think you'll want, isn't free but there again it isn't nearly as expensive as XMLSpy (which I agree is extremely good).
I've got it running using Eclipse 3.2 . Seems to run OK but I haven't used it enough to know if it's any good. The bits I would use more are only in the Pro version e.g XPath, XSLT etc.
Hope that's of some use.
Jim
