looking for some speakers for new build do i need sound card?
28 Dec 2010
I am looking for some speakers for my new build i was wondering do i need to buy a sound card for the speakers to work. I am also looking for advice on which sound card and which speakers with a budget of about £50 on both or just speakers. Thank you appreciate any feedback. ;)
You don't need a soundcard as your Motherboard will have onboard audio. What are you going to be using the speakers for but? Music, Games or Movies?
Likely you will be wanting 2.1 then, unless you have no space for a sub. I'd just get a reasonably good set of 2.1 speakers, and forget the sound card. Just use the on-board audio.
The Creative S2 speakers are a good set of 2.1 speakers for under £50 if you know where to look.
I looked at picking a setup for £25 last week.
CREATIVE S2 2.1 SPEAKERS MF0385
