I'm not to bothered with the bottom, it's clear there is no illustration from the picture to get it right, as long as there is an initial hole to start the spiral off, that's good enough for me. The bottom would have just been cool to add in as I'm sure they are there for some reason. Defo happy with that view though!
The dims I put in are just the width of the tubing +1mm, guessing the rest but I think they are quite accurate, what did you use in your design? If that can fit in 12mm hardline, I'm happy with that, if it can fit 16 + 12mm, more then what I asked for, that's amazing! (I assume 12mm would fit nicely as it's all curved). As far as 3D printing goes, don't know all that much about it, I feel the thicker plastic will help it retain shape from any heat that may apply over, unsure though, what do you think? Some of the heating will prob be done whilst in the design, otherwise it would be a lot of tubing having to heat and would cool before being able to wrap it all.
What do you mean a fillet around the spiral ?
