Looking for suggestions - ITX case
6 Jan 2013
Rollergirl
I'm looking for a new case, and would like it to be small, light and compact. Preferably ITX but appreciate I may need to go mATX.
I have a bit of a criteria / spec requirement:
1) Preferably, able to accommodate a 360mm radiator. If not able to accommodate a radiator, then a Dark Rock Pro air cooler.
2) Accommodate 3 slot GPU, length around 320mm.
Have any of you built anything similar recently?
TIA
Jonsplus Z20 - if you can get one, then its worth it. It slike NR200 but mATX and a bit more space to play around.
Much more choice now with small mATX cases which reduces the need for an ITX board. SFX or SFX-L modular PSUs still useful for maximising internal space for cables.
My current one is the NR200P MAX with fitted AIO & PSU. Will fit a 320mm GPU The FE cards look particularly good in it. Not as compact.
Thermaltake TR100 takes a big GPU but more limited on the CPU cooling. Some bright colours too!
The Lian Li A3 is M-ATX but quite compact, worth a gander and would save you some cash/effort with the build if it's within your size range.
Plenty of colour/design options with it too, smart bit of kit imo.
Using one and is great. My main issue was getting a decent motherboard that would allow more than 2 NVMEs, not cripple the lanes and first slot PCI-E. Finally MSI offer the B850M Mortar. Very solid motherboard. The lime text doesn’t bother me as I’m using the mesh panels and all RGB off.
