Everything worked fine until I put the new i7 chip in well not exactly new, got it off eBay. I’ve even put in my old chip and my old graphics card and nothing changed. Could something have blown on the board?Take out cpu and double check for bent pins
Try using onboard gfx
Maybe try a different psu
I tried with old cpu 1 stick of ram I’d already taken out card. Still nothing.Possible something has popped
Try taking it out of the case and try with just old cpu,1 stick ram and onboard gfx
and a heatsink ofc![]()
outside of case?I tried with old cpu 1 stick of ram I’d already taken out card. Still nothing.
I’ve taken it in to local repair shop. They’re gonna call sometime next week to let me know what problem is and how much it’ll cost. Really hoping it’s cpu. Thanks for all your help. Much appreciated.outside of case?
this rules out a short
Yes. If it turns out to be cpu then I’ll be demanding a refund.Sounds like a problem caused by changing to new CPU. Maybe cooler mounting, but most likely in the CPU to CPU mount. Maybe a bent pin. Is this with same cooler / same cooler mount? I've seen similar when cooler mount / back-plate was shorting something out.
You are assuming you did not damage the socket removing old CPU and installing new CPU. Basic process of elimination is system that was working and did not work after changing CPU, but when original CPU is re-installed system works it's bad CPU. Your system is not now working with original CPU, meaning the CPU you bought may not be the problem. It might be that somehow there was damage to CPU socket while changing CPUs. Not saying this is for sure, but it is a possible cause of problems like this that we've seen here on forum before. Hopefully it's just the new CPU is bad, but socket damage/bent pins could possibly be the cause of your problem.Yes. If it turns out to be cpu then I’ll be demanding a refund.
I was very careful when taking out old one and putting new one in but yes can't really explain why it didn't work when i put old one back in. I know on motherboard 2 sata connectors broke so might need new motherboard anyway. Woman I spoke to on phone when arranging booking said if it's motherboard then it would need complete rebulid so could be more but not sure it would need that if they replace it with another board that's socket 1150 which they could.You are assuming you did not damage the socket removing old CPU and installing new CPU. Basic process of elimination is system that was working and did not work after changing CPU, but when original CPU is re-installed system works it's bad CPU. Your system is not now working with original CPU, meaning the CPU you bought may not be the problem. It might be that somehow there was damage to CPU socket while changing CPUs. Not saying this is for sure, but it is a possible cause of problems like this that we've seen here on forum before. Hopefully it's just the new CPU is bad, but socket damage/bent pins could possibly be the cause of your problem.
I have no idea where you took it (don't really care) but many computer repair shops do not have anyone who is really a good computer tech/builder doing the work. I'm assuming your computer skills are minimal and that is why you took it to a shop, but I will say most shops have only marginally skilled tech so "Let the buyer beware" should be kept in mind.I was very careful when taking out old one and putting new one in but yes can't really explain why it didn't work when i put old one back in. I know on motherboard 2 sata connectors broke so might need new motherboard anyway. Woman I spoke to on phone when arranging booking said if it's motherboard then it would need complete rebulid so could be more but not sure it would need that if they replace it with another board that's socket 1150 which they could.
Been going to this place for years to buy pc parts.I have no idea where you took it (don't really care) but many computer repair shops do not have anyone who is really a good computer tech/builder doing the work. I'm assuming your computer skills are minimal and that is why you took it to a shop, but I will say most shops have only marginally skilled tech so "Let the buyer beware" should be kept in mind.
