So you want fans for exhausting case air. Where is the air coming from? Case can't exhaust air that isn't first flowing into case, so good intake fans are first priority, not exhaust fans. With good intake and enough exhaust venting exhaust fans are not even needed with temp being basically the same at same noise levels .. same principle as cooler or radiator only having front fans instead of push/pull. Push/pull only improves temps at full speed and then by only a couple degrees. Single fan running 50-100rpm faster (at same noise level as push pull) cools the same as push/pull.hi just looking for the best fans for exhuasting my case, i am not fussed on sound at all so just what ever is the best in dragging/pushing heat is all i am looking for. the sizes must be 120mm and i am looking at getting 4
